Connection Problems Part 3......
Y2J
For the last week my router has been resyncing on its own once a day, only since last week it has been doing this and i am now on  G.992.3 annex A (was .5)
Here are my router stats
Link Information
Uptime: 0 days, 3:16:20
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 4,224
Bandwidth (Up/Down) [kbps/kbps]: 443 / 4,248
Data Transferred (Sent/Received) [MB/GB]: 84.56 / 1.10
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 28.5 / 47.0
SN Margin (Up/Down) [dB]: 22.0 / 9.0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,545 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 1,318
HEC Errors (Up/Down): 0 / NA
With the lower speed i have now compared, to the maximum bandwith of 6000 i have less errors on my line, its allmost like the higher the throughput the more fec crc and hec errors i get im talking millions of errors i get over a period of a week.
Sn margin has shot up too.
Wont let me do a fault check through the website says we are in the process of closing my last fault ( febuary 2011)
Nothing wrong my end as engineer has been out said nothing wrong with anything in the house, so its the exchange or yourselves.
As i said with the last faults i have had since december when all this started i dont want to leave plusnet been here since 07, but i might have to due to continuing problems.
Lee
10 REPLIES 10
Y2J
Re: Connection Problems Part 3......
Still unplayable gaming, think the line is banded/interleaved again due to the rysncs
Y2J
reynced again uptime 2 hours  Cry
jojopillo
HI Y2J,
Test socket? From what I recall from last time you were using an extension to the bedroom.
Jojo Smiley
Y2J
Hi joe again ,the engineer that come out said its fine ( the extention )
Y2J
Still wont let me do a fault check through the member centre.
jojopillo
Hi Lee,
Ok, I've done some checks... Your line's not banded and 9db SNR is about right for your attenuation. I don't doubt what the engineer says about the extension but it would have to be in the test socket, having changed filters for us to look at it further and raise it as a possible fault.
Jojo Smiley
Y2J
I dont get why now on  G.992.3 annex A (was .5)
Speed test results
Apr 19, 11:42 4830 kbps (604kB/s)
Monday 22:57 3658 kbps (457kB/s)
I dont think im on adsl2+ anymore
jojopillo
Hi Lee,
You are on ADSL2+ your router will sometimes decide it will get a better connection on ADSL2 (G.992.3) so will use that. That is quite normal behaviour.
Jojo Smiley
Y2J
I still cant do a fault checker through the member centre
"You've chosen to close the Broadband Troubleshooter
We're currently closing your problem report.
This can take a few minutes. If you still need to report a problem, please try again later.
If you have problems with your broadband in the future, please come back here to report them."
Return to My Account
jojopillo
Hi Y2J,
I can see there's a problem with raising a fault at the moment and this is a problem we are investigating which is happening on a few accounts. At the moment, looking at your line stats I would raise a fault. However, if  you are still using the extension we would need you to plug into the test socket and take it from there. Regardless of whether the engineer said the extension was ok we don't guarantee speeds on extensions. If you plug it into the test socket so I can run another check I'll be in a better position to advise you.
Jojo Smiley
