Connection Issues
RG2
Connection Issues
Are there any issues in my area?
My router intermittently disconnects, turns orange and then returns to blue. This has happened a couple of times this evening. My connection is terrible to, the speed and responsiveness is nothing like it has been.
9 REPLIES 9
Fixes: 387
Re: Connection Issues
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
willcutforth
Fixes: 113
Hey there @RG2 I can see there is an active connection now and has been for a couple of days. Have you had any further issues?
 Will Cutforth
RG2
We haven’t been at home much since the issues, but appears to have resolved itself.
willcutforth
Fixes: 113
Awesome glad it's resolved itself. See how it goes over the next few days and if it reappears please do let me know.
 Will Cutforth
RG2
Still having issues. Router is a solid orange colour and has been for the past hour or so.
I've switched on and off and reset the router but still not working. My mobile data with EE isn't work either so is it something area specific / related?
Fixes: 387
@RG2 You have two unrelated but co-incidental issues. The EE connection (phone) has nothing to do with the Hub/Broadband (Plusnet)
RG2
Yes, but they are both brands within the BT Group. Consequently, I wondered if there was network / infrastructure related issues in my area as neither were working.
Fixes: 387
They both work on different infrastructure.
willcutforth
Fixes: 113
Hey there @RG2 Just checked it all and I can see there was a drop when you messaged but none since, and that was the only drop in 6 days. Am I right in thinking that?
 Will Cutforth
