Connection/Gateway dropped?
- Connection/Gateway dropped?
24-04-2013 2:59 PM
Just checked my BQM -:
Seems i dropped just before 12pm today was on gateway - PTN-AG04 any reason why i dropped or just a random disconnection? (Have not got a fixed I.P so didn't reconnect)
Did anyone else drop on this gateway?
Had to jump gateways a few times to find a better pinged one (Seem to get higher ping on certain ones was on PCL-AG05 after the drop) now on PCL-AG04 which seems great.
Message 1 of 7
(1,161 Views)
6 REPLIES 6
Re: Connection/Gateway dropped?
24-04-2013 3:32 PM
I doubt that's gateway related as I can see a number of drops around that time:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13668138543607.png"/>
It's been up since then so it looks fine now but let us know if you spot any further issues.
Adam
Adam
Message 2 of 7
(579 Views)
24-04-2013 3:47 PM
Yeah the number of drops was probably me trying to get a gateway with a good ping after the initial drop it may have been at least 10 hops (maybes more) before i found the desired gateway... It had been solid for days, was just curious if it was my connection that dropped or a gateway problem really.
But I'll keep an eye on it and it has been solid since, it may have just been a random re-sync or something ???.
Cheers :).
Cheers :).
Message 3 of 7
(579 Views)
24-04-2013 5:04 PM
My PPP session dropped from the same gateway, ptn-ag04, a few seconds after midnight last night/this morning, reconnected on ptn-ag03 which had undergone maintenance yesterday morning. I wondered if this was network balancing related though Plusnet normally post an announcement if that is taking place.
Otherwise perhaps BT work in the exchange which is progressively being commissioned for fibre at the moment.
David
Message 4 of 7
(579 Views)
25-04-2013 11:29 AM
Message 5 of 7
(579 Views)
25-04-2013 2:33 PM
Message 6 of 7
(579 Views)
26-04-2013 10:17 AM
Message 7 of 7
(579 Views)
