Connection Flaky DNS timeouts and Laggy Gaming
- Connection Flaky DNS timeouts and Laggy Gaming
29-08-2014 4:53 PM
I have posted my issues in the gaming forum, but as I am quite desperate to get this sorted asap, so I can enjoy my weekend downtime playing FIFA.
Recently, last week or so, my connection has become flaky, DNS timeouts, solved by using Google DNS, slow browing, even though I am synched at 23000, as I practically live next door to the exchange, can somebody from Plusnet or anyone who can help, look at the uotrace below and advice, what I need to do.
I am connected via ethernet to my home hub 3, and prior to these last few weeks, I had no real lag/latency issues which gaming or browsing.
Host Name IP Address Hop Ping Time Ping Avg % Loss Pkts r/s Ping best/worst
* Unknown Host * 192.168.1.254 1 3ms 3ms 0% 98 / 98 3ms / 7ms
lo0-central10.ptw-ag02.plus.net 195.166.128.196 2 511ms 38ms 0% 98 / 98 18ms / 511ms
link-a-central10.ptw-gw01.plus.ne212.159.2.148 3 19ms 21ms 0% 98 / 98 17ms / 80ms
xe-0-2-0.ptw-cr01.plus.net 212.159.0.248 4 19ms 24ms 0% 98 / 98 17ms / 108ms
te-4-2.car5.London1.Level3.net 217.163.45.249 5 23ms 68ms 1% 97 / 98 18ms / 416ms
* Unknown Host * 0.0.0.0 6 0ms
ae-58-223.ebr2.London1.Level3.net4.69.153.137 7 19ms 26ms 0% 98 / 98 18ms / 224ms
* Unknown Host * 0.0.0.0 8 0ms
ae-47-47.ebr1.NewYork2.Level3.net4.69.201.46 9 86ms 91ms 0% 98 / 98 86ms / 207ms
ae-39-39.ebr2.Washington1.Level3.4.69.201.89 10 98ms 100ms 0% 98 / 98 98ms / 130ms
* Unknown Host * 0.0.0.0 11 0ms
ae-4-90.edge2.Washington1.Level3.4.69.149.206 12 94ms 95ms 0% 98 / 98 92ms / 166ms
* Unknown Host * 4.79.23.202 13 95ms 97ms 0% 98 / 98 93ms / 223ms
* Unknown Host * 159.153.93.2 14 122ms 100% 0 / 97
* Unknown Host * 159.153.225.30 15 93ms 97ms 0% 97 / 97 93ms / 205ms
meav5-pub.pt.iad.ea.com 159.153.226.105 16 94ms 97ms 0% 97 / 97 93ms / 182ms
Message 1 of 4
(941 Views)
3 REPLIES 3
Re: Connection Flaky DNS timeouts and Laggy Gaming
30-08-2014 12:02 AM
Have you tried gateway hopping?
Message 2 of 4
(530 Views)
30-08-2014 5:49 AM
Quote from: Xreyuk Have you tried gateway hopping?
Please elaborate?
Also I am somewhat dismayed that no one from Plusnet has had the courtesy to reply to this or my thread in the gaming forum, add to the un replied ticket and I am seriously contemplating a move away from Plusnet.
Message 3 of 4
(530 Views)
01-09-2014 11:28 AM
Hi bolt786,
I'm sorry that nobody got back to you on this, unfortunately we only man the forums one week days between 9am and 5:30pm and given the time you posted and how busy things were on the Friday due to the outages, I'm afraid this wasn't picked up on.
From looking at the details you posted it seems that you've hit a 511ms ping on the ag02 gateway which could well be the cause of the issue. Have you seen any improvement on this over the weekend?
If you need to have a look at hopping gateways, you can check which one you're connected to by checking here and then if you disconnect your connection from the router config page (you only need to drop the PPP session, no need to reboot the router) and then reconnect and check the gateway again to make sure you've hopped over to another one.
Hope this helps!
Hope this helps!
Message 4 of 4
(530 Views)
