Connection Drops Part 2
- Connection Drops Part 2
Re: Connection Drops Part 2
09-02-2011 10:20 PM
Let's see what happens in the next couple of days.
Jojo
09-02-2011 11:12 PM
"Dear Mr Jackson,
As per our conversation, following the engineer visit, I have sent a request to reset your line to try and improve your speeds, this should be within 72 hours. We now believe your fault is resolved. If you have any further problems, please call us back on 0845 10 0200 and select option 6, 3.
I have sent a request to reset your line to try and improve your speeds, this should be within 72 hours."
Hope it sorts it out
11-02-2011 12:51 PM
Im now on 700kbps internet now, is this meant ot happen when my line is meant to get reset?
Uptime: 0 days, 0:09:41
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 976 / 2,136
Bandwidth (Up/Down) [kbps/kbps]: 931 / 728
Data Transferred (Sent/Received) [MB/MB]: 3.11 / 23.11
Output Power (Up/Down) [dBm]: 12.5 / 16.0
Line Attenuation (Up/Down) [dB]: 28.0 / 45.0
SN Margin (Up/Down) [dB]: 7.0 / 19.0
Loss of Framing (Local/Remote): 73 / 0
Loss of Signal (Local/Remote): 131,082 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 131,091 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 63 / 0
HEC Errors (Up/Down): 7 / 0
UPDATE_________
Just restsrded router back to 3.2 mb
11-02-2011 2:02 PM
I've arranged for a faults agent to call you and explain it all.
Jojo
14-02-2011 7:50 PM
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,016 / 3,988 (was 5000)
Is this meant to happen ?
15-02-2011 9:03 AM
19-02-2011 12:46 AM
Dont know what to do now to be honest
lee
19-02-2011 4:54 PM
I'll investigat that more for you on Monday.
Jojo
19-02-2011 5:01 PM
21-02-2011 9:53 AM
line's been stable now (see below) so I'll look at getting the banding removed later. I'll let you know when it's done.
Jojo
22-02-2011 2:56 PM
22-02-2011 3:04 PM
I'll contact BT again now for you and post back here soon.
Jojo
22-02-2011 3:53 PM
The banding's been lifted now so you should see the sync rate is up but I'll have to check the IP profile in a bit to see when that goes up so I can make changes on your account.
Jojo
22-02-2011 3:57 PM
lee
23-02-2011 2:59 PM
The maximum bandwith ****alternates every time i refresh the page so will i ever be able to get 4.5 mb?
Uptime: 0 days, 23:39:35
DSL Type: G.992.5 annex A
****Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,004 / 5,236
Bandwidth (Up/Down) [kbps/kbps]: 443 / 5,176
Data Transferred (Sent/Received) [MB/GB]: 172.63 / 2.24
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 28.0 / 46.0
SN Margin (Up/Down) [dB]: 22.0 / 6.0
Loss of Signal (Local/Remote): 131,073 / 0
Error Seconds (Local/Remote): 199,285 / 0
CRC Errors (Up/Down): 2,584 / 131,312
HEC Errors (Up/Down): 15 / NA
Thanks jo
Lee
