Connection Drops Part 2
- Connection Drops Part 2
Re: Connection Drops Part 2
25-01-2011 5:01 PM
I'm trying to find out why you can't access the faults tool. While I am looking into this please don't try to access it.
Thanks,
Jojo
25-01-2011 5:34 PM
It seems there have been a few issues like this. I have given your details to the person investigating this and I will update you in the morning. In the meantime please don't try to access the faults tool as this will stop us being able to fix it.
Thank,
Jojo
25-01-2011 5:35 PM
26-01-2011 1:15 PM
looks like the faults guy raised this manually last night for you.
Jojo
26-01-2011 8:41 PM
Link:csa removed - BOT - DSL Logged Faults
8:24pm, Tuesday 25 Jan 2011
*** Internal ***
KBD fail
Moving to correct pool
DCN issue
Please action accordingly
Kind regards,
Link:csa removed
Adie:red csa name removed as per link:rules
27-01-2011 2:44 PM
I've had one of the faults team look at this for you and after running a few tests he's sent the ticket back to you with a few questions. The sooner you could answer then then they can progress it further for you.
Jojo
27-01-2011 4:43 PM
27-01-2011 5:03 PM
I've informed the faults guy that you have responded to the ticket.
Jojo
27-01-2011 9:29 PM
I will report back soon , out !
UPDATE_____
In test socket (22:04) il leave it downstairs into the test socket till sat morning/ Afternoon.
Anything to look for stat wise jo?
Cheers
Lee
28-01-2011 12:09 PM
I think it's being dealt with by the faults agent and AFAIK he has a cunning plan!
Jojo
28-01-2011 5:37 PM
Curious about this AFAIK and whats the cunning plan ? LOL
As i said on the ticket il test it when it arrives.
Thanks Joanne
28-01-2011 11:16 PM
AFAIK = As Far As I Know. I think the router was probably his cunnig plan as he's bet me a drink that the voyager you're using is having ADSL2+ compatibility issues.
Jojo
29-01-2011 10:25 AM
Get up connect all fine strange
UPDATE___
Just did a speed check
Date Download Speed Upload Speed
Today 10:28 4040 kbps (505kB/s) 658 kbps (82.3kB/s)
WOW never had 4mb before, 4.5 profile too
30-01-2011 1:10 PM
Because i have tested playing before 12pm and after 12am and its fine beetween these times its unplayable.
Fair usage etc, as FIFA uses P2P to connect to each other.
31-01-2011 12:09 PM
