Connection Dropouts
- Re: Connection Dropouts
Connection Dropouts
03-01-2015 2:07 PM
Like the title says, i'm having dropouts as frequently as every 15secs. I had a similar issue on Christmas Day. Is there any maintenance going on or is it something that will resolve itself. Thanks in advance, Epic.
03-01-2015 2:31 PM
It's also quite interesting that the connection was solid for 8 days between Christmas day and today, only for the problem to come about again.
No maintenance is going on currently - can you therefore confirm if you've been able to do any tests, such as plugging the router into your test socket?
03-01-2015 3:27 PM
03-01-2015 3:29 PM
03-01-2015 3:46 PM
This is your connection. When you have problems, I need you to note the sync light on the router. Does this flash or change colour?
I don't think you are being DDossed.
03-01-2015 4:28 PM
03-01-2015 7:23 PM
05-01-2015 9:08 AM
05-01-2015 10:52 AM
05-01-2015 8:50 PM
The line has completely gone now. It's been ~2 hours since it first went out. I want to try and do some more troubleshooting before I report a fault.
05-01-2015 9:03 PM
TP LINK WD8980
Power LED:Solid,router is powered on
ADSL LED:Solid,ADSL Line is synced and ready to use
Internet LED:Off,There is no internet connection. Check if router is operating in bridge mode.
Wireless 2.4GHz:Flashing,Sending or receiving data
Wireless 5.0GHz:Flashing,Sending or receiving data
WPS:Off,No information on this state
LAN 1:Flashing,Sending or receiving data
LAN 2-4:Off,No device connected.
07-01-2015 11:32 AM
11-01-2015 12:13 PM
11-01-2015 12:53 PM
17-01-2015 8:14 PM
