Connection Details
- Connection Details
Connection Details
21-09-2009 1:52 PM
When I go to Connection Setting and then Connection Details in the member centre and click the link to open Automatic configuration for a BT Line I get prompted to Find, Save or Cancel I do not get an Open option. Can any one one help thanks?
Message 1 of 9
(1,466 Views)
8 REPLIES 8
Re: Connection Details
21-09-2009 1:55 PM
Hiya,
Whilst not overly familiar with that option, I strongly suspect that it is for a dial up modem, so wouldn't be applicable in your case.
Message 2 of 9
(666 Views)
21-09-2009 1:59 PM
You only get the open option in Internet Explorer not in Firefox and even in IE8 it doesn't have a program to open it
Message 3 of 9
(666 Views)
21-09-2009 5:50 PM
Running IE7 on Windows Vista so should we be able to open it?
Message 4 of 9
(666 Views)
21-09-2009 6:43 PM
Probably not as it won't recognise the file type.
Why do you want to open it anyway
Message 5 of 9
(666 Views)
22-09-2009 10:11 AM
Sorry - I should have been more specific.
You don't want to open it.
Message 6 of 9
(666 Views)
22-09-2009 12:13 PM
Yes, my Hubby wanted to open it to see if it could shed any light on why our connection keeps dropping but does not look like we can get it to open
Message 7 of 9
(666 Views)
22-09-2009 12:33 PM
No - it won't help at all.
Going back a few years, everyone would use a USB modem to connect to the broadband service. I believe that that link is designed to automatically configure your USB ADSL Modem (which you don't have).
Message 8 of 9
(666 Views)
22-09-2009 12:48 PM
Thanks for info.
Message 9 of 9
(666 Views)
