Connecting wirelessly on Billion 7800N
- Connecting wirelessly on Billion 7800N
09-01-2013 3:42 PM
Im looking for some help in getting my Nexus 7 tablet to connect to my router. Ive been using the Technicolor router supplied by PlusNet until it started throwing a fit. I swapped to the billion i had used with my previous ADSL provider and configured it to work with my FTTC connection and via ethernet it works okay. But i cannot wirelessly, the android device hangs on either "authenticating" or "obtaining ip address". I have checked the wireless key i have set endlessly and i have inputted it correctly and flushed then re-entered the WLAN settings on the Billion's GUI. Also i have tried to wipe the connection off the tablet and start as if entering a new connection with bohj DCHP and Static IP in the settings but still it wont connect. Any ideas please???
Thanks in advance
Matt
Re: Connecting wirelessly on Billion 7800N
09-01-2013 3:47 PM
From my limited experience of such matters (probelms conencting ipads & iPhones), this has all the hallmarks of the router having no DHCP addresses available. As a test, you might care to remove the WiFi security settings. That would allow you to confirm conenctivity without the confusion of passwords being a problem (case etc).
HTH,
Kevin
09-01-2013 3:58 PM
09-01-2013 4:06 PM
Matt
09-01-2013 4:28 PM
09-01-2013 4:38 PM
Matt
09-01-2013 4:43 PM
Some devices won't work on 11 upwards.
09-01-2013 4:57 PM
Matt
09-01-2013 5:28 PM
Quote m looking for some help in getting my Nexus 7 tablet to connect to my router
Have you tried connecting the Nexus to any other wireless network ? and did it connect ok ? it would confirm if it's a router or a Nexus 7 issue.
I've a Nexus 7 and it's connected fine to any network I've tried.
