Connecting router to my TV
mikeyw
How can I connect my router to my TV
2 REPLIES 2
Fixes: 314
Re: Connecting router to my TV
Does your TV have wired and/or wireless network connections ?
How far is the TV from the router ?
idonno
Champion
Fixes: 6
Which TV? With my TV, with WiFi it was just a case of selecting the network, input the password and it connected. But recently I've changed to an ethernet connection, which was even easier. Just connect the cable between the TV and the router and it automatically connected. I might add I did go into the TV menu to tell it to forget the WiFi connection.
There is always the WPS button option but I've never been a fan of pressing the button. Seems to have a life of its own if it connects or not.
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
