Connecting another computer
- Connecting another computer
- « Previous
- 1
- 2
- Next »
Re: Connecting another computer
29-09-2011 5:39 PM
Just tried the ping. Seems fine ( Looks pretty much exactly the same as my pc connected to the internet) 0 packets lost etc.
Just compared ipconfigs aswell only difference is that on the XP machine the Node Type is unknown. Is this important?
Message 16 of 18
(182 Views)
29-09-2011 5:52 PM
So you have connection to the internet.
Have you checked your LAN Settings in IE ? (Tools->Internet Options->Connections->Lan settings)
Are any of them enabled? If so then try disabling them.
Not sure about the unknown node type
Message 17 of 18
(182 Views)
29-09-2011 6:19 PM
Just checked those settings. Turned off the proxy setting option. Internet is up and running
Thanks alot for the help.
Message 18 of 18
(182 Views)
- « Previous
- 1
- 2
- Next »
