Connecting a printer to the router
1pds
My first post - apologies if my question has been covered elsewhere or if I've posted it in the wrong place...
I have a MacBook Pro laptop which is connected to to the internet via a Technicolor TG582N Router which was supplied by PlusNet.  My router doesn't have a USB port.  I have an Epson Stylus Photo R300 and I would like to print wirelessly from my laptop to my printer.  Is this possible?  If so, does anyone have an Idiots Guide to making it happen?  I'd also like to print from my iPad2 and my iPhone 4s via the router if that's possible? Thanks!
1 REPLY
batchelorboy
Re: Connecting a printer to the router
As far as I can tell, your printer can only connect through a USB port and not either by wireless or Ethernet connection.  So it will either have to be connected to a computer which is switched on and connected to your network or you will have to use a dedicated print server.  Here's a link to some of those http://www.broadbandbuyer.co.uk/default_ShopGroup.asp?ShopGroupID=19
