Connecting a DGN2200 to a DGN1000 wirelessly
- Re: Connecting a DGN2200 to a DGN1000 wirelessly
23-08-2011 6:07 PM
OK, so this may not be possible but lets see who fancies a challenge !!
Main router is a DGN2200, works great.
I have my old DGN1000 and want to use this in a different room to be able to plug a wired device into the network using the old DGN1000 kinda like a bridge....I dont really want to spend out on more equipment unless I have to, but after looking through several forums I have a feeling that the DGN1000 does not like being a bridge....any help would be wonderful !
Cheers
Glen
Cheers
Glen
Message 1 of 3
(1,550 Views)
2 REPLIES 2
23-08-2011 7:52 PM
Depends whether your DGN1000 is capable of working in AP Client Mode. If it does then great.
Message 2 of 3
(339 Views)
23-08-2011 8:28 PM
I'm pretty sure that the DGN1000 doesn't support Client Mode but that's exactly what you need. Have a look at this thread http://community.plus.net/forum/index.php/topic,98030.0.html ; there's a couple of reasonably cheap router/APs on there that WILL support client mode.
Message 3 of 3
(339 Views)
