Connecting Plusnet TG582n to Fibre or cable modem.
machare
Is there a version of the firmware for the Plusnet TG582n that would allow a PPPoE connection to a fibre modem?
Similar to what is described on the Zen website here: http://support.zen.co.uk/kb/KnowledgebaseArticle.aspx?articleid=11307
Or configuration file that would enable this facility.
Similarly, is there a configuration file for a TG575v7 that does this?  I am sure that I saw one some time ago.
Michael Chare
Fixes: 20
Re: Connecting Plusnet TG582n to Fibre or cable modem.
Yes, considering Plusnet ship the TG582n with a different firmware as their fibre router.
See this thread for links to the fibre firmware and the flashing program.
machare
Many thanks.  Just what I want.
Do you happen to know if I can continue to use the adsl modem in the router after applying the patch?
I assume that it is port 4 (on the right as you look at the ports on the router) that does the PPoE?
I am running the 8.4.4.I firmware on my 582n. Do you know if there is a later, non PPPoE version?
Fixes: 20
I don't know which ethernet port becomes the WAN port, and I doubt the ADSL modem will be available.
As for newer firmware, various 10.X.Y.Z ADSL versions have been floating around being tested for some time:
http://community.plus.net/forum/index.php/topic,108966.0.html
http://community.plus.net/forum/index.php/topic,110170.0.html
machare
Many thanks.
