Connecting CCTV DVR Box to Router - Ports 34567 and 34599 Filtered
- Connecting CCTV DVR Box to Router - Ports 34567 an...
23-02-2016 1:53 PM
I've had a CCTV system installed with the cameras connected to a DVR box. The DVR has been connected to my router with the Port Forwarding setup for ports 34567 and 34599 (TCP). I'm using the Dynamic DNS service via a dyndns account.
The problem I have is that whenever I use a port check tool such as http://canyouseeme.org it very rarely shows 34567 as being accessible - it states that the connection timed out. It does sometimes show the port as been available but more often than not the connection times out. I've also used http://www.ipfingerprints.com/portscan.php which shows the ports as being filtered. Subsequently, I can't remotely access the cameras connected to my DVR box.
Do Plusnet block ports 34567 and 34599? If not, any other ideas as to why the ports don't seem to be accessible? I've tried turning my Firewall off but that's not made a difference. Nor has ticking the 2 UPnP options. (Needless I'm not an expert in this area, an engineer from the installation company carried out the setup for me and said that the settings he's made are what he does for every other customer so he doesn't know why it's not working although he did say he's never had a Plusnet setup to do).
My router is a Sagemcom Router 2704N.
Thanks,
Thanks,
Message 1 of 3
(5,663 Views)
2 REPLIES 2
Re: Connecting CCTV DVR Box to Router - Ports 34567 and 34599 Filtered
24-02-2016 10:54 AM
Message 2 of 3
(5,263 Views)
24-02-2016 4:58 PM
Hi Adam,
Thanks for the reply.
Yes, I've setup port forwarding as per the attached screenshot.
Message 3 of 3
(5,263 Views)
