Connecting 2 hubs to Plusnet router using same network
rshaines
Hi, I have a Plusnet hub router with two hubs connected with ethernet cables. I would like to use one wireless network to enable me to log on with  one password for my iPads or mobile phones where ever I am throughout our  house. However, the hubs will not connect when setup for an existing network and they only connect when setup for a new network.  So I have to use 3 passwords! Any ideas how I can over come this?
CJT-80
Re: Connecting 2 hubs to Plusnet router using same network
@rshaines
Are you trying to use one of the Hubs as a Wireless Access Point? - Just to send out a wireless signal.
EDIT: If you are read this post: https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/td-p/138...
Kind Regards,
CJT
Fixes: 31
Hi @rshaines
I would suggest taking a look at the thread @CJT-80 linked as it would contain the relevant information if you were using a second Hub1.
If you are using any 3rd party hardware then I'm afraid we would not have the ability to assist on this matter, but I'm sure on of our Forum Members will have the require knowledge.
Kind Regards,
Alisdair
 Alisdair C
