Connected to gateway but not dns server
- Connected to gateway but not dns server
Re: Connected to gateway but not dns server
03-11-2015 8:22 PM
03-11-2015 8:36 PM
Welcome to Microsoft Telnet Client
Escape Character is 'CTRL+]'
Microsoft Telnet>
03-11-2015 8:37 PM
03-11-2015 8:48 PM
03-11-2015 9:00 PM
ipconfig /all ......post the output of that.
then do these -
ipconfig /flushdns
ipconfig /registerdns
ipconfig /release
ipconfig /renew
then ipconfig /all again and post the new output (unless identical to the previous)
Then check that Telnet is still enabled.
Then at the Command Prompt type telnet 192.168.1.254
If you get a response saying two sessions are already open, kill them.
Then check all the RSL settings and try RSL again.
03-11-2015 9:05 PM
03-11-2015 9:05 PM
C:\Users\SJH>IPCONFIG/ALL
Windows IP Configuration
Host Name . . . . . . . . . . . . : SJH-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : Belkin
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-26-9E-57-57-73
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 70-1A-04-3F-46-09
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC
Link-local IPv6 Address . . . . . : fe80::28b0:fa11:edf8:ab42%15(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.64(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, November 3, 2015 9:04:01 PM
Lease Expires . . . . . . . . . . : Wednesday, November 4, 2015 9:04:01 PM
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 369107551
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-7B-E9-98-00-26-9E-57-57-73
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:8c5:3935:3f57:febf(Preferred)
Link-local IPv6 Address . . . . . : fe80::8c5:3935:3f57:febf%8(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 738197504
NetBIOS over Tcpip. . . . . . . . : Disabled
03-11-2015 9:17 PM
03-11-2015 9:20 PM
03-11-2015 9:24 PM
03-11-2015 9:25 PM
C:\Users\SJH>ipconfig /registerdns
The requested operation requires elevation.
03-11-2015 9:30 PM
Have your tried tracert 212.159.6.9 yet?
03-11-2015 9:35 PM
Microsoft Windows [Version 10.0.10240]
(c) 2015 Microsoft Corporation. All rights reserved.
tracert 212.159.6.9
Tracing route to cdns01.plus.net [212.159.6.9]
over a maximum of 30 hops:
1 3 ms 1 ms 1 ms dsldevice.lan [192.168.1.254]
2 37 ms 36 ms 38 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 185 ms 37 ms 37 ms link-a-central10.pcl-gw01.plus.net [212.159.2.168]
4 * 37 ms 38 ms xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5 222 ms 37 ms 39 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 37 ms 37 ms 36 ms cdns01.plus.net [212.159.6.9]
Trace complete.
03-11-2015 9:39 PM
03-11-2015 9:40 PM
