Connected but no throughput
- Connected but no throughput
07-07-2009 8:51 PM
Hi All,
This evening everything looks fine with my connection but I've got absolutely no throughput. Anybody else having this problem? It's very frustrating! Thanks Simon.
Message 1 of 4
(900 Views)
3 REPLIES 3
Re: Connected but no throughput
07-07-2009 9:03 PM
what ip address does your router say you are using. if its 172.***.***.*** you have this http://community.plus.net/forum/index.php/topic,76791.0.html pretty common problem which should clear after 10-20 mins hopefully
Message 2 of 4
(387 Views)
07-07-2009 11:21 PM
Thanks for the reply. I was on the dodgy ip address, turned off my router for a bit and then when I turned it back on it had fixed itself. What's confusing me slightly is that I thought I was on a static ip product. Thanks again and best regards, Simon
Message 3 of 4
(387 Views)
07-07-2009 11:46 PM
You never got as far as connecting to the Plusnet network, that's why you didn't get your Plusnet assigned IP address.
Message 4 of 4
(387 Views)
