Connected but no internet
K23
Hi anyone else constantly not having internet even though says connected. It's becoming a daily thing now 😔
9 REPLIES 9
Fixes: 334
Re: Connected but no internet
Welcome to the forums, @K23 . Are you a new customer, or has this developed recently?
K23
I've been a customer since August. It was doing this on a weekly basis it's now becoming almost every day.
Fixes: 334
Sorry for the late reply.
Welcome to the forums. For Community members to be able to help, information from these two sites:-
BT Broadband (obscuring your phone number) andBTW Performance Tester - Over a wired (ethernet) connection please report the 'Additional Diagnostics', and sight of the Help Desk tab would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
RealAleMadrid
Fixes: 66
@jab1  Generally the "Connected no Internet" scenario is always a Wi-Fi problem where the router has an internet connection but for some reason the devices are not connecting via Wi-Fi in this case I don't think your standard diagnostics will help very much. The best test is to check with a ethernet connection to the router, if that works the Wi-Fi is to blame. Surprisingly many people have no devices with an ethernet port and rely totally on wi-fi connections.🤔
Fixes: 334
OK, @RealAleMadrid - you are probably correct, but I just wondered if anything might show. True about many not having an ethernet-enabled device, which I find scary.
adam945
Fixes: 113
Thanks for getting in touch @K23 and I'm sorry to see that you're having problems with your service.
We're going to need to arrange an engineer visit here, tests on the line are showing a high resistance imbalance, please respond to the open ticket on the account stating your availability, and let me know once you have, I'll get it raised. Smiley
** INTERNAL **
KBD
Copper Line Test
Circuit ID: CBUK63007664 Service ID:
Telephone NO.: NA Test Executed On: 26-12-2021 13:27:00
Status: Fail MFL: CA OR Test ID: hws00556dat02:290370764
Test Outcome: CIDT FAULT - HIGH RESISTANCE IMBALANCE DETECTED DTR: T307
Copper Test Details
  A to E B to E
Capacitance: 184 NanoFarad 183 NanoFarad
DP Line Length Estimate: 1386 Metres DN Line Length Estimate: 1395 Metres
Celerity:   Line Loss: 21.33 dB
Line Stability:
Fault Report Advised: Y
Service Level: 2
BRAGOutcome: Bad
Faceplate: Cannot Be Detected
Radius
 Adam
 Plusnet Help Team - Leeds
LaurenB
Fixes: 131
Hiya @K23 I can see you have added a reply on the ticket, so I have replied on there for you with some further information.
 Lauren Barry
Fixes: 235
Off topic...
@RealAleMadrid wrote:
@jab1  Generally the "Connected no Internet" scenario is always a Wi-Fi problem where the router has an internet connection but for some reason the devices are not connecting via Wi-Fi ...
Actually it is the other way around ... there is a WiFi connection, but there is no connection to the internet.  This can happen for a number of reasons - the router has no up-link (as appears to be the case here) or (for some obscure reason) the DHCP service has not issued a usable IP address.
RealAleMadrid
Fixes: 66
@Townman  You are quite right, my only excuse is that I have had a stinking cough and cold over the hoiidays and my brain has ceased to function in any logical way.☹️
