Congested Exchange?
bruces
Congested Exchange?
Noticed in the evenings my ADSL connection that is served by the Leith exchange has been getting less responsive (high latency) & speeds are roughly halved, despite sync speeds staying the same. The connection is stable sync wise with only occasional (by me) router reboots causing tge connection to drop. So I assume it must be congestion at the exchange rather than interference.
I setup ping monitors and it seems to back up what I'm seeing.
My other Plusnet connection at my business property (also ADSL but different city & exchange) is not affected and for further comparison my partners Sky FTTC.
The top one is the connection seeing the issues. (Ignore the period after Midnight as I started downloading files from work)
Can someone check to see if there are congestion issues at the Leith exchange abd if there plans to increase capacity?
bruces
Re: Congested Exchange?
And another 2 ping monitors from other days very little usage at the peak times.. Yet large spikes.
Fixes: 10
Could you run this speedtest: http://www.thinkbroadband.com/speedtest.html
If the x6 speed is normal and the x1 speed is bad that is a classic sign of congestion.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bruces
http://www.thinkbroadband.com/speedtest/results.html?id=142274368996581346984
Seems that way.
Tested on a wired computer and the router stats are:
ADSL Link Downstream Upstream
Connection Speed 5675 kbps 736 kbps
Line Attenuation 48.0 db 26.0 db
Noise Margin 6.0 db 5.2 db
Fixes: 187
Hi there.
Your community username appears to be linked to your Business account rather then your home property.
If you can PM me your username I can look further into that for you.
 Matthew Wheeler
bruces
It's that line I have an issue with.
Plusnet Staff
Plusnet Staff
Fixes: 4
I am just running some tests on your line now to investigate.
