Congested Exchange?
- Re: Congested Exchange?
Congested Exchange?
31-01-2015 9:45 PM
Noticed in the evenings my ADSL connection that is served by the Leith exchange has been getting less responsive (high latency) & speeds are roughly halved, despite sync speeds staying the same. The connection is stable sync wise with only occasional (by me) router reboots causing tge connection to drop. So I assume it must be congestion at the exchange rather than interference.
I setup ping monitors and it seems to back up what I'm seeing.
My other Plusnet connection at my business property (also ADSL but different city & exchange) is not affected and for further comparison my partners Sky FTTC.
The top one is the connection seeing the issues. (Ignore the period after Midnight as I started downloading files from work)
Can someone check to see if there are congestion issues at the Leith exchange abd if there plans to increase capacity?
Message 1 of 7
(1,114 Views)
6 REPLIES 6
31-01-2015 9:48 PM
And another 2 ping monitors from other days very little usage at the peak times.. Yet large spikes.
Message 2 of 7
(684 Views)
31-01-2015 10:09 PM
Could you run this speedtest: http://www.thinkbroadband.com/speedtest.html
If the x6 speed is normal and the x1 speed is bad that is a classic sign of congestion.
Message 3 of 7
(684 Views)
31-01-2015 10:39 PM
http://www.thinkbroadband.com/speedtest/results.html?id=142274368996581346984
Seems that way.
Tested on a wired computer and the router stats are:
ADSL Link Downstream Upstream
Connection Speed 5675 kbps 736 kbps
Line Attenuation 48.0 db 26.0 db
Noise Margin 6.0 db 5.2 db
Seems that way.
Message 4 of 7
(684 Views)
02-02-2015 9:11 AM
Message 5 of 7
(684 Views)
02-02-2015 7:38 PM
It's that line I have an issue with.
Message 6 of 7
(684 Views)
03-02-2015 10:38 AM
I am just running some tests on your line now to investigate.
Message 7 of 7
(684 Views)
