Confused why a OS would make a difference to Broadband speed
UFOned
I am selling my home and internet is important these days. So I have been checking my speeds on different sites and on Win10. The Win10 speed on 3 site checks were giving me download 3.8mbps and upload .7 to .8. I live in the countryside and that is not too bad here. However, I tested this on three same sites on Linux Fedora 24 and I was just astonished at the lower figures it came up with. I would never have thought an OS would effect the speeds? Could someone explain why please?
And is there any unit I can buy to increase or boost the speeds?
Thanks for reading friends
Fixes: 20
Re: Confused why a OS would make a difference to Broadband speed
There should be no difference. How were they connected both via ethernet or one via wifi?
VileReynard
Seasoned Pro
Fixes: 10
Time of day can be significant, if your exchange is a bit overloaded.
UFOned
I always use Ethernet cable.  And I also have wireless as well.  But that is always turned off.  There are reasons I have both  But 99% cable.  I had just switched from Win10 to Fedora.
UFOned
Switched within  minutes and its mostly stable at 3.8
VileReynard
Seasoned Pro
Fixes: 10
Check that your phone line has no interference (noise) on it.
The only unit which will give a much better speed is the day you get access to a fibre connection.
Fixes: 10
MTU?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
UFOned
  This is a small hamlet which I doubt will ever get faster broadband for quite a while.
UFOned
MTU?
Fixes: 10
http://www.kitz.co.uk/adsl/MTU2.htm
VileReynard
Seasoned Pro
Fixes: 10
You don't need to worry about MTU's - provided the router MTU is set correctly.
See https://en.wikipedia.org/wiki/Path_MTU_Discovery
Linux handles RWIN's dynamically.
UFOned
That link goes a little over my head.  But I will digest and assess what I can understand.  Thanks.
Fixes: 20
If it was/is the same hardware, was Fedora downloading updates at the time? Only thing I can think off not already mentioned.
UFOned
I hadn't ticked the box to allow it.  But thanks for the thought I will check out and see. Thanks for your suggestion
