Confused about figures.
- Confused about figures.
19-03-2014 9:04 AM
Re: Confused about figures.
19-03-2014 9:21 AM
I've checked over your line and it doesn't look very good at all. Could you please raise a fault at http://faults.plus.net and complete the questions on the troubleshooter?
19-03-2014 10:04 AM
19-03-2014 12:12 PM
19-03-2014 12:23 PM
Here's your graph, as requested
<img src="http://community.plus.net/visualradius/generated/image13952316718416.png"/>
Our Faults Team should be able to get a good idea of the location of the fault. If they can't we may progress the issue for an engineers visit.
19-03-2014 4:33 PM
19-03-2014 4:36 PM
19-03-2014 4:48 PM
19-03-2014 4:53 PM
Your line is actually shorter than the DSL Checks show - Faults will pick this up anyway.
If your Line Attenuation is showing higher than it should do, your speeds will be slower as a result - simply because the exchange thinks your line is longer than it actually is.
19-03-2014 4:59 PM
19-03-2014 5:20 PM
I am only a short distance from my cabinet - if the trees and railway line weren't in the way I could probably hit it with a well-aimed cricket ball - well almost.
Unfortunately, for some reason, although I'm under 2 miles from the exchange, the best I can get as I said earlier is 3.5.
19-03-2014 5:23 PM
Quote from: Chris I think there's something wrong with the reported Line Attenuation.
Cheers again Chris - if I can get closer to the 7 in those shots - AND get a SNR that doesn't fall through the floor after sunset, I'll be a happy bunny.
20-03-2014 8:36 AM
Right on cue last night at 1915, my SNR fell below 1.0, and any internet activity was impossible. I attach a couple of RSL graphs from last night and one from this morning (which STILL shows a scarily low figure). I can still use the net this morning, but in the last 10-15 minutes I am getting pages not loading fully unless I refresh them two or three times.
Can someone pass this info to the faults team, please - I don't want to push my ticket to the back of the queue by adding to it.
20-03-2014 9:12 AM
I've got a Sky ADSL line and my downstream attenuation is 48.5dB and get 7.5Mb or so. I know with LLU, you get marginally improved sync speeds - but you should be getting nearly 2x what you're getting now.
20-03-2014 9:14 AM
