Confused about Premium Speeds
- Confused about Premium Speeds
Re: Confused about Premium Speeds
18-12-2009 10:28 AM
@Chris, as you can see below my router is now reporting the Up Bandwidth 864kbps - great - but the Down Bandwidth is still 7.616 and the DSL Type: G.992.1 annex A so still no ADSL2+ or 9Mbps line speed.
Uptime: 0 days, 9:03:33
Bandwidth (Up/Down) [kbps/kbps]: 864 / 7,616
Output Power (Up/Down) [dBm]: 9.5 / 17.5
Line Attenuation (Up/Down) [dB]: 4.5 / 12.0
SN Margin (Up/Down) [dB]: 15.0 / 16.5
Loss of Framing (Local/Remote): 80 / 0
Loss of Signal (Local/Remote): 7 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 10 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Annette
18-12-2009 10:50 AM
18-12-2009 11:01 AM
As you are aware updating the firmware solved my problem but mine was a BT Voyager 2110 but annapp's router is is a new Thomson 585v7 supplied by Plusnet. Surely this would have the latest firmware pre installed would it not?
I agree though it's worth seeing if it has the latest version of firmware installed.
18-12-2009 1:05 PM
I thought you could still get the Upstream speed uncapped on WBC Max 8Mb/s ( ADSL1) ?
SamKnows seems to think you can http://www.samknows.com/broadband/21cn_broadband.php ( about 1/2 down the page )
Quote WBC Max 8Mb/s - First up we have WBC Max 8Mb/s which provides essentially the same circuit as ADSL Max. However, as can be seen on all WBC products, there is an option for an uncapped upstream variant of the product. On standard ADSL (ITU G.992.1), this would allow for an upstream of up to 1Mbps. Interestingly, whilst the standard product has an upstream capped at 448kbps, there is no 832kbps capped product - which is what current ADSL Max business products are based upon.
Edit: to me it still looks like BT never actioned the switch to ADSL2+ and all they've done with the latest order Chris placed, is uncap the Upstream.
18-12-2009 1:57 PM
I'm not sure how I tell if I have the latest firmware, its version 8.2.23.0, I cannot see anything that allows me to check manually for firmware updates. As I said the router is new from Plusnet last week.
Annette
18-12-2009 3:15 PM
I suppose its just possible that the router is configured to force ADSL1 ( G.992.1 ) but I can't see anywhere in the manual that shows its possible ( I dont have a TG585 so can't actually look in the menus ) and I wouldnt have thought Annette had done that judging by her other replies.
18-12-2009 5:51 PM
Thanks for the continued help.
Annette
18-12-2009 7:27 PM
Quote we have looked through the router menus but there is no way to manually set the connection type (ADSL 1, ADSL2+ etc) so the connection is automatic.
That was my assumption to be honest, some routers have the ability to force a specific connection type but I guessed that you hadn't set yours. It was just useful to check that possibility and confirm it for Mand & Chris. My best guess is still that BT messed up your change to ADSL2+ and have set your line to ADSL1. Mand & Chris don't work weekends as far as I know so TBH I wouldn't expect anything to happen until Monday but I guess at least you have a broadband connection albeit at 8Mb.
Lets hope either Mand or Chris pick it up on Monday and sort it out.
Quote Thanks for the continued help.
You're welcome
Ian
19-12-2009 11:45 PM
This may help, but if things didn't go well, you can always reset the router to the factory settings and reconfig with your username and password
20-12-2009 10:12 AM
Thanks for that, this morning I received the following response on my support ticket for this problem:
" I have requested a refresh of your line to see if it can reset itself. Please allow 48 hours for this to complete"
So we'll wait until Tuesday to see what happens before messing with the router:-)
Annette
20-12-2009 10:31 AM
I'm getting confused here we just looked at the router and its reporting a bandwidth increase in both up/down but still ADSL 1:
Bandwidth (Up/Down) [kbps/kbps]: 1,024 / 8,128
Then did a BT speedtest:
Download speedachieved during the test was - 6043 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 1024 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.92:22.89:63.2 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
So has the line refresh already worked? But still no ADSL2+
Question: If the router was forcing ADSL1 but the line was actually ADSL2+ would this effect the connection rate reported by the BT Speedtester?
Perhaps we should try to telnet the router like RamiDoodle suggested?
Thanks once again
Annette
20-12-2009 11:41 AM
Quote So has the line refresh already worked? But still no ADSL2+
Looks like the line refresh has happened, but all it's done is remove what is called 'interleaving'. With interleaving enabled most routers will only synch at a maximum of 7616 Kb whereas the max on ADSL1 is actually 8128Kb. Now that ( presumably ) interleaving is off after the line refresh your router is now synching at the maximum 8128Kb. I still don't think you have been put on ADSL2+.
Quote Perhaps we should try to telnet the router like RamiDoodle suggested?
It might be worth a try, just to prove one way or the other. If you try setting to G.992.5 as per Rami's link using the
xdsl debug multimode config=g992.5_annex_a command. If your line has not been set to ADSL2+ then I don't believe it will synchronise at all with that setting and your DSL light will continue to flash on the router. If you then reset it back to multimode as per the link then it should synch again.
Actually before you do that, I've just downloaded the cli guide and I think there's a command which will show the current setting ( without changing anything ).
Telnet to the router as per Rami's link and login then type the command xdsl config adslmultimode and post the output. It should probably say something like adsl|adsl2|adsl2plus.
20-12-2009 12:30 PM
{admin}=>:xdsl config adslmultimode
Missing parametervalue at the end of command :
Unknown command.
Annette
20-12-2009 12:42 PM
Not having a TG585 myself I'm working from the CLI manual which is not the world's best at giving examples.
I've attached a screenshot of the manual page I'm looking at if that helps
20-12-2009 12:49 PM
{admin}=>xdsl config
ADSL configuration:
adslmultimode = adsl2plus
detect-lop = enabled
syslog = disabled
So does what does that mean? The line is ADSL2+? So is the router not connecting correctly?
Annette
