Configuring xbox live with Thomson Router TG585v7
- Configuring xbox live with Thomson Router TG585v7...
29-05-2010 2:59 PM
I can't get my xbox live to work with this router. I'd appreciate any setup information / tips. All other wireless devices in the house work fine (Wii, laptops. ipods etc) but
I can't get anywhere with the xbox connection, it states that it can't find any network and I can't seem to configure it. I have to admit networking is not one of my strong points so please keep it simple!!
Any advice appreciated.
Dave
Dave
Message 1 of 5
(2,414 Views)
4 REPLIES 4
Re: Configuring xbox live with Thomson Router TG585v7
29-05-2010 5:24 PM
The two settings that worked for me when running xbox live through this router were to enable plug and play, and to turn off strict/safe mode.
I can't remember offhand where you find them on the GUI tho. Perhaps the Games and Applications page?
-- gyre --
-- gyre --
Message 2 of 5
(685 Views)
09-06-2010 6:44 AM
Thanks for the tip - sadly still no joy and a disgruntled teenage son with an xbox subscription he can't use.
Message 3 of 5
(685 Views)
09-06-2010 7:02 AM
Doesn't Xbox live work at all? Don't suppose you're in a position to try a wired instead of a wireless connection? That's always worked fine for me out of the box.The fact you don't seem to be able to connect at all suggests that you might not be entering the Wireless security settings correctly in the console's adapter settings?
Message 4 of 5
(685 Views)
13-06-2010 11:26 PM
Thanks for your response. Xbox live doesn't work at all. Haven't tried connecting via a wired connection. I'm not even "offered" the wireless security settings in the console's adapter settings - as though the console isn't seeing the wireless adapter plugged in to it. Have tried another wireless adapter unit, but no difference. The adapters both display a red light (not flashing) Is this pointng to a fault in the console?
Message 5 of 5
(685 Views)
