Configuring, Buffalo WZR-HP-G450H to replace PN supplied TG528n
- Re: Configuring, Buffalo WZR-HP-G450H to replace P...
06-08-2013 9:21 AM
Good morning. I have just had delivered this morning the above Buffalo product.
Having opened the box and read through the included airstation quick setup guide (guide shows a WZR-HP-G300NH2) I am assuming this is a generic quick start guide.
I am not sure how to go about setting up the buffalo to replace the TG528n. My PN welcome letter has all the details regarding accounts and passwords, but I am at a loss as where and how to input them for the Buffalo.
Any help or guidance will be appreciated.
Ps: I have the fast fibre installed.
Message 1 of 4
(2,070 Views)
3 REPLIES 3
Re: Configuring, Buffalo WZR-HP-G450H to replace PN supplied TG528n
06-08-2013 9:35 AM
Hi, I can't seem to find a downloadable manual for the WZR-HP-G300NH2.
Basically you need to set its WAN connection type to pppoe and input your PlusNet username & password.
Message 2 of 4
(585 Views)
06-08-2013 9:42 AM
Just done a quick google search and the link below is the download for a pdf user manual for the WZR-HP-G450H.
Hope it helps
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CC8QFjAA&url=http%3A%2F%2Ffoo...
Hope it helps
Message 3 of 4
(585 Views)
06-08-2013 10:13 AM
Thanks for that. Seems like it might be supplied with DD-WRT formware as standard. If so page 6 seems to cover the WAN setup. Set connection type to pppoe and then enter your PN details.
Message 4 of 4
(585 Views)
