Configure router
BillyP
Configure router
Is it possible to configure my router prior to the connection arriving
4 REPLIES 4
Fixes: 387
Re: Configure router
There is no point in doing this before you are told to do so, in fact trying it could cause problems.
BillyP
Just want to change the wi-fi SSID, so I can change all my devices ahead of time ...
There is always the reset button!
Fixes: 582
@BillyP that shouldnt be a problem. Just connect to the new router using a wired (ethernet) connection with the router disconnected from the phone line (or ONT if you are FTTP). Then go to 192.168.1.254 using a browser. You will need the router admin password ( on the back of the router ) to make any changes. Make sure to save any changes.
Fixes: 387
Deleted
