Configure old router as Wireless Access Point
- Configure old router as Wireless Access Point
02-11-2014 12:51 PM
After several false starts and battles with the GUI I have managed to configure an old TG585 as a wireless access point with the following changes:
- set the SSID to be the same as the main router
- set the wireless key to be the same as the main router
- made sure the WAP ip address was different to the main router and outside the DHCP range of the main router
- turned off DHCP in the WAP
- turned off firewall in the WAP
- set WAP and main router wireless channels to be different (actually 6 and 11)
However I noticed that on test I sometimes couldn't connect to the internet through the WAP even with a laptop right next to it (though I could connect using an ethernet cable). Other times it seems to work OK. I expected to get 'seamless roaming' with the laptop always connecting to the stronger signal. What am I missing here?
Message 1 of 3
(1,221 Views)
2 REPLIES 2
Re: Configure old router as Wireless Access Point
02-11-2014 3:03 PM
Try changing the SSID to Wireless Name_Ext
So add '_Ext' to end of SSID. As there can be complications if there are the same SSID in a close range and broadcasting the same channel and password.
NE
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 2 of 3
(899 Views)
03-11-2014 8:40 AM
Thanks, NE, I will try that. One thing which now occurs to me is that the old router uses just the 802.11b/g standards but the main router uses 802.11b/g/n.
Message 3 of 3
(899 Views)
