Complete drop outs and lag in between
- Complete drop outs and lag in between
27-06-2013 8:16 PM
Thanks in advance for any help on the matter,
Chris
Re: Complete drop outs and lag in between
28-06-2013 9:38 AM
I've posted a graph of your connection below.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13724082431168.png"/>
Does your phone line have any interference or crackling when you use it?
I'd also suggest running through our faults wizard at http://faults.plus.net so we can get this resovled.
28-06-2013 2:25 PM
That's all it said when i ran the faults tester
Help? haha
Sidenote: There is no interference or crackling when using the phoneline.
28-06-2013 2:42 PM
28-06-2013 2:47 PM
28-06-2013 4:10 PM
If you are able to connect to your test socket at all it would be worth it to help rule any internal issues out.
28-06-2013 5:29 PM
I've logged into th member centre and there is no ticket raised? Where can i check on the status of it?
29-06-2013 6:42 PM
OK: final edit lol After further investigation it is only the Xbox that is suffering from the lag HOWEVER it is ALL devices (Laptops, Phones, Deskptop PC, Xbox and Kindle Fire's) that are subject to the complete drop out of all internet connection.
When it comes to the internet as a whole, the speeds are fine up down and with ping and jitter etc and the thing that confuses me the most when it comes to the Xbox is that i can stream with netflix and sky player etc BUT in xbox Live Partys chat is distorted and undecipherable and online play is too laggy to play and i physically can't download the update for Black Ops 2 meaning i can;t even load the game at all. It makes no sense how it's only a certain couple of things are affected and others aren't on the same device.
Like i say though, and as the graph in the first initial reply shows, the connection as a whole has jus cut up 3+ times a day for the past week minimum.
I genuinly don't understand what's going on haha
This is the average speed test we get, pretty normal.
01-07-2013 11:13 AM
01-07-2013 6:02 PM
02-07-2013 9:09 AM
The drops where your internet light was red but you still had connectivity will not show on the graphs as you were still connected.
If you check your ticket this afternoon is will have been updated for you.
02-07-2013 3:02 PM
02-07-2013 3:11 PM
02-07-2013 3:29 PM
02-07-2013 3:36 PM
