Complete Pass Though
bigdingus
Hi guys.
Just got upgraded to Fiber.
However my Netgear DGND3700 is now no good as I need to use the Technicolor one...... Or do I?
If I must, then can anyone tell me if I can configure it to allow total pass through.
All I want to do is use it as a link between the fiber modem and my own (Better) router.
Please tell me I don't need to port forward ALL ports for each thing I have connected. There's got to be a way I can make it invisable.
bigdingus
Re: Complete Pass Though
What a numpty.
I appears I can use my own router without using the Plusnet piece off ****............. Did I say that out load?
Fixes: 12
the DGND3700 is a DSL router though, not a fibre router
Fixes: 45
but it has an Ethernet WAN(EWAN) facility so it can be used with Fibre
goldenfibre
Quote from: chenks76
Rubbish. I do have this router. DGND3700 and DG3700v2 and both will work with FTTC using Wan port from the openreach modem
Fixes: 12
right OK clever clogs....however coming in 8 hours after the previous post kinda takes the shine off your "rubbish" comment.
i googled it and on the netgear site it listed it as a router with DSL modem, therefore i took it to being a DSL router.
only when delving into the further spec do you see it has a WAN port.
but yes, you can have the rosette for putting me firmly in my place.
enjoy the smug feeling for the rest of the evening.
Fixes: 21
Makes a change that he was right about something  Grin
