Compatible routers for FTTC
Shermo
So i have had fibre for around 18mths - 2 years with you, the router supplied is now giving me some grief with random drops outs etc. I know its not the connection itself because it happens while home networking also. I was wondering is there a list of compatible routers i can choose from? or any suggestions?
Fixes: 247
Re: Compatible routers for FTTC
Here's a list... http://www.broadbandbuyer.co.uk/Shop/ShopSearch.asp?CategoryID=711&Sort=1
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
markm9
Hi Shermo, Asus routers are quite popular with a lot of PN customers, i personally use Asus RT-N56u, easy to set up, theres also a seperate thread for ASUS RT-N66U on forum,
Shermo
thank you both
Will have a look at the Asus one never had a problem with there components
