Compatible routers for FTTC
- Re: Compatible routers for FTTC
26-12-2013 8:58 PM
So i have had fibre for around 18mths - 2 years with you, the router supplied is now giving me some grief with random drops outs etc. I know its not the connection itself because it happens while home networking also. I was wondering is there a list of compatible routers i can choose from? or any suggestions?
Message 1 of 4
(1,562 Views)
3 REPLIES 3
26-12-2013 10:06 PM
Here's a list... http://www.broadbandbuyer.co.uk/Shop/ShopSearch.asp?CategoryID=711&Sort=1
Message 2 of 4
(1,183 Views)
26-12-2013 10:10 PM
Hi Shermo, Asus routers are quite popular with a lot of PN customers, i personally use Asus RT-N56u, easy to set up, theres also a seperate thread for ASUS RT-N66U on forum,
Message 3 of 4
(1,183 Views)
26-12-2013 11:16 PM
thank you both
Will have a look at the Asus one never had a problem with there components
Message 4 of 4
(1,183 Views)
