'Clr rej. LTb still evident'
robin35
Can you tell me what  ''Clr rej. LTb still evident'' means.
Re: 'Clr rej. LTb still evident'
Where are you seeing this?
If it is in a ticket, what is it related too?
James
Hi Robin,
Clear reject means that we have passed the fault back to BT for further investigation.
LTB still evident means that the Lower Threshold Breach (your line is synchronising at a speed lower than your fault threshold rate) is still being seen by us.
It's an internal note in relation to your fault.
robin35
Hi Jameseh thanks for the info
Regards Robin
