Clash of Clans Loading Problem
- Clash of Clans Loading Problem
10-06-2015 10:35 PM
Hi all,
Just got online with plusnet today with a plusnet router using unlimited ADSL.
Everything was going well until I tried Clash of Clans on my Android Phone. It connects ok, web pages work on the phone but not my game. It just shows the loading screen and reaches 100% then does nothing.
A google search reveled the ports that i need (9339 and 80). Ive put them in the routers Advanced Settings -> Port Forwarding but that had no effect. Ive also tried to put the device in the DMZ to see if that would get it working but no joy there either.
Any ideas?
PS. I have to walk down the street to the local shop to play my game using their WiFi.
Any ideas?
Message 1 of 9
(2,455 Views)
8 REPLIES 8
Re: Clash of Clans Loading Problem
10-06-2015 10:39 PM
Have you checked that your Plusnet Firewall is off https://portal.plus.net/my.html?action=firewall
Message 2 of 9
(1,622 Views)
10-06-2015 10:59 PM
It says "Your firewall is currently Off."
Message 3 of 9
(1,622 Views)
11-06-2015 9:10 PM
Well i found a solution. More like a work around though.
I just created a VPN on my phone and now i can tunnel my way to London to access my game (not ideal). Until i find the actual problem and fix it, this will have to do. I spent last night getting messages of my village getting attacked and being powerless to do anything about it. Sucks.
Message 4 of 9
(1,622 Views)
15-06-2015 6:27 PM
Hi there I am having the same problem. I tried the online chat and that was a waste of time I was told to contact clash of clans as the problem was was with them. I was also told that perhaps clash of clans does not work on plusnet.
Needless to say I was not happy.
I had a dig around under the stairs and found an old netgear router and set that up and bingo clash of clans loaded.
But like a dog with a bone I rang plusnet and they are trying to sort it and have promised a call back tomorrow.
I will let you know how it goes.
Message 5 of 9
(1,622 Views)
15-06-2015 6:42 PM
my son is quite happily playing it (sadly) on his iPad right now, so it's probably not PN as a whole..
Message 6 of 9
(1,622 Views)
15-06-2015 10:57 PM
I narrowed it down to my plus net router but I dont know if it is a general problem with this model router or if I have a faulty router.
Message 7 of 9
(1,622 Views)
16-06-2015 12:34 PM
Plus net called me as promised and the problem has been resolved.
Clash of clans now loads every time.
Message 8 of 9
(1,622 Views)
16-06-2015 12:37 PM
another MTU case as these are recent accounts perhaps?
Message 9 of 9
(1,622 Views)
