Clarification of terminology
- Clarification of terminology
25-11-2011 7:54 AM
Hi
When I ckech my connection speed, I get the following readings for example
Download Upload
Today, 07:32 4329 kbps (541kB/s) 944 kbps (118kB/s)
Can you please explain - in lay terms please as I'm not too computer literate
the difference between the kbps figure and the kB/s figure
THanhs
Download Upload
THanhs
Message 1 of 9
(1,595 Views)
8 REPLIES 8
Re: Clarification of terminology
25-11-2011 8:04 AM
basically B = byte b = bits, but the full reasoning takes a lot of reading http://en.wikipedia.org/wiki/Byte
1 Byte =8 bits
Mega can be 1000 or 1024
Confusing aint it
1 Byte =8 bits
Confusing aint it
Message 2 of 9
(693 Views)
25-11-2011 11:07 AM
Quote from: pierre_pierre Mega can be 1000 or 1024
No it not
kilo is 1000 or 1024
Mega is 1000k or 1024k
Message 3 of 9
(693 Views)
25-11-2011 11:30 AM
Not strictly accurate
kilo is 1,000 mega is 1,000,000
It is only the IT geeks who corrupted it by using binary calculation
Message 4 of 9
(693 Views)
25-11-2011 11:40 AM
Mebibyte is 1024KB.
Message 5 of 9
(693 Views)
25-11-2011 11:48 AM
And to get really geeky
http://en.wikipedia.org/wiki/Mebibyte
or
http://en.wikipedia.org/wiki/Orders_of_magnitude_%28data%29
or
Message 6 of 9
(693 Views)
25-11-2011 11:51 AM
and confusing
Quote Mebibyte is not commonly used. Instead, megabyte is often used to mean 1000 x 1000, 1024 x 1024, and even 1000 x 1024 bytes. Such usage can be confusing and inconsistent. For example, Microsoft's Windows XP operating system shows a file of 220 bytes as "1.00 MB" in its file properties dialog, while showing a file of 106 (1000000) bytes as 976 KB; but Apple's Mac OS X 10.6 would report a 106 byte file as 1 MB
Message 7 of 9
(693 Views)
25-11-2011 11:53 AM
Quote from: Oldjim It is only the IT geeks who corrupted it by using binary calculation
No it's not, mathematicians will also use 1024 when dealing with base 2 numbers.
Message 8 of 9
(693 Views)
25-11-2011 11:55 AM
But they won't use the kilo prefix - not if they are proper mathematicians
Message 9 of 9
(693 Views)
