Chromecast buffering unwatchable iplayer
- Re: Chromecast buffering unwatchable iplayer
07-12-2014 9:37 PM
Anyone know of a work around - when trying to use a chromecast connected to plusnet it just keeps on buffering then plays for a few seconds then stops again.
its usualy at its worse after 7:30/8pm
ive tried re-booting the router a few times but that dosnt seem to make much difference
Message 1 of 5
(2,695 Views)
4 REPLIES 4
07-12-2014 9:47 PM
You could try what i have done and left the plus net router as a modem then an older router as the actual router, i find the plus net router to be weak and incapable to do everything i need.
Message 2 of 5
(1,219 Views)
07-12-2014 11:22 PM
I am having issues with games not playing videos buffering having to use my phone for internet, would you recommend "binning" their router?
Message 3 of 5
(1,219 Views)
09-12-2014 8:24 PM
I doubt it's anything to do with the modem/router.
@pint
That sounds a bit like exchange congestion starting at that time. Also can you check and post your Current Line speed (Login required) (don't post your phone number)
Also post the TG582n Full DSL stats just do a copy and paste.
@dhep1
Could you do the same please.
@pint
@dhep1
Message 4 of 5
(1,219 Views)
10-12-2014 9:34 AM
Hi guys.
Sorry to hear about the issues you've had
@pint
Testing is showing no issues with your line. The connection is stable and you should be getting around 9mbps and there's no reported capacity issues at your exchange. Do you have issues with any other devices at that time as I suspect it's more of a wireless issue.
@dhep1
Your SNR target is low and your upload is currently capped so that won't help if your playing online games. I've reset the line to increase the SNR and I've also placed the order to uncap your upload which will complete tomorrow.
If there's anything else we can help with please let us know.
@pint
@dhep1
Message 5 of 5
(1,219 Views)
