Chnages at the FTTC cabinet
Routefinder
Hi all
I have yet to take up fibre but as at the start of 2014 my Cab was FTTC enabled.  Now just thought I would see if there was any different info to learn about I put the phone number in the checker again and got this nugget copied & pasted.
FTTC Range A (Clean) 47.8 34.8 10.6 7 -- 24-Sep-14
FTTC Range B (Impacted) 40 22.4 10.6 5.7 -- 24-Sep-14
WBC ADSL 2+ Up to 2.5 -- 1 to 4 Available
ADSL Max Up to 2 -- 1 to 3.5 Available
WBC Fixed Rate  1  -- -- Available
Other Offerings
Fibre Multicast -- -- -- 24-Sep-14
Copper Multicast -- -- -- Available
FTTC is currently not available on this cabinet due to following reasons:- Sorry your cabinet is temporarily unavailable, capacity will be restored as soon as possible.
Sorry the copy and paste loses all the formatting but it is the "availability date" of 24th September and the last sentence in bold that intrigues me. I wonder what happened and when and what does it mean bearing in mind the cab was supplying fibre services in January this year.
Fixes: 62
Re: Chnages at the FTTC cabinet
It means that the CAB is full and they need to add more capacity to it
Routefinder
I had in inkling it was a capacity question but the phrasing is somewhat arcane!
Do you know what the max capacity in the CAB's is?  The reason I ask that is that I have seen two sizes of  FTTC CAB, a single door & a double door version.  The one I am getting the data for is one of the double door versions Smiley
Ref the increasing capacity of the CAB?  Do they blow more fibres through to it or are all the fibre bundles present so it is remote DSLAM's (not sure that is the right description for the FTTC cab 'unit' as the DSLAM is in the exchange) that need adding to?
Fixes: 4
The cable is already in situ. They just add further banks of connections, about 120 at a time I think. In my village it has happened several times where the cab is full & only when they have additional incomplete orders do BTOR add extra capacity. A strange way of doing business.
