Checking line drops
mexicano
Checking line drops
Can someone from PN please check how many times my line has dropped/disconnected in the last 2 weeks?
My download speeds have been going up and down dramatically recently and I think it's because of the disconnections.
It's been down to 2Mbps some days and I can't even watch catch-up tv without the buffering! The upload speed is impossible.
Today is a good day for both Smiley
Any help will be appreciated.
Fixes: 231
Re: Checking line drops
I've attached a graph showing how many drops you've had below.
It looks like there's the odd day here and there where it drops quite alot but aside from that it's currently stable.
Our tests aren't showing any issues with the connection with regards to speed either as you should be getting around 7mbps.
Are you connecting over a wired or wireless connection?
 Matthew Wheeler
mexicano
Hi Matthew,
I am wired. I have also replaced the filter and plugged into the test socket. That's what PN would normally tell me to do.
PN also replaced the router a few weeks ago because of the same problems but it seems it hasn't helped.
Every time the line drops I have to wait for the router to settle down. I'm always told I have to wait up to 10 days for this to happen!
I only renewed my contract in January so very annoyed that I will have to wait until December to try and change providers.
Moderator's note by Mike (Mav): Post released from Spam Filter
Fixes: 231
If you're having issues over a wired connection I'd recommend raising a fault by going here
 Matthew Wheeler
Fixes: 238
Moderator's note:
Several near identical posts caught and released from Spam Filter and duplicates removed.
Forum Moderator and Customer
mexicano
Matthew,
I have just raised a ticket.
I will wait and see what is the outcome.
Fixes: 78
Hi Mexicano, I've just reported the fault with our suppliers for you.
We should be able to update you further soon.
 Adam Walker
