Check out these speed results!!!
- Check out these speed results!!!
02-09-2009 9:56 AM
Date Download Speed Upload Speed
Today 08:33 129 kbps (16.1kB/s) 380 kbps (47.5kB/s) Share
Yesterday 08:43 130 kbps (16.3kB/s) 335 kbps (41.9kB/s) Share
Monday 09:04 231 kbps (28.9kB/s) 380 kbps (47.5kB/s) Share
Sunday 10:46 228 kbps (28.5kB/s) 382 kbps (47.8kB/s) Share
Saturday 10:26 228 kbps (28.5kB/s) 382 kbps (47.8kB/s) Share
Aug 27, 08:38 916 kbps (115kB/s) 380 kbps (47.5kB/s) Share
Aug 26, 09:52 918 kbps (115kB/s) 380 kbps (47.5kB/s) Share
Aug 25, 08:50 925 kbps (116kB/s) 381 kbps (47.6kB/s) Share
Aug 24, 09:46 1370 kbps (171kB/s) 379 kbps (47.4kB/s) Share
Aug 21, 08:30 687 kbps (85.9kB/s) 382 kbps (47.8kB/s) Share
Aug 20, 08:42 1367 kbps (171kB/s) 380 kbps (47.5kB/s) Share
Aug 19, 08:48 1382 kbps (173kB/s) 381 kbps (47.6kB/s) Share
I've had problems with my connection for about four years, just about had enough.
Vincent
Vincent
Message 1 of 9
(1,522 Views)
8 REPLIES 8
Re: Check out these speed results!!!
02-09-2009 10:09 AM
Hi Vincent,
Your connection speeds are almost definitely related to your dropping connection.
Can I ask what you have tried doing so far to ensure the problem is not at your end?
Message 2 of 9
(743 Views)
02-09-2009 10:29 AM
Hi James,
So far I've checked the connections/filters are all in place and firmly connected. If you look at my details, you will see that this is an ongoing problem, Plusnet sent BT out two or three years ago and they found no problems at my end.
When I do a Speedtest test, it pings at about 45ms, if that helps. I am using XP sp3 and Firefox 3.0.13.
Vincent
Vincent
Message 3 of 9
(743 Views)
02-09-2009 10:43 AM
Thanks Vincent.
Those pings are perfectly fine on an interleaved connection (which is normal).
Can I ask if you managed to try using a different router at all when you were having problems previously?
Message 4 of 9
(743 Views)
02-09-2009 4:22 PM
James,
I've been out for a few hours, hence the late reply.
I was having problems with a D-Link 300t and getting a connection through a ps3 player, so I replaced it with a Netgear 834g v4 about six weeks ago. No problems with the Netgear. The D-link at times would stop me connecting to the net and I'd swop over to a Plusnet supplied Dynamode, which was always good for a connection but start up was a bit messy. I must say though, whichever modem/router I've used the speeds have never been affected.
Vincent
Vincent
Message 5 of 9
(743 Views)
02-09-2009 4:24 PM
Thanks again.
Do you nornally turn off your router when you're not using it, or do you normally keep it turned on?
It doesn't matter either way, I've just trying to get a gauge of how poor the connection actually is.
Message 6 of 9
(743 Views)
02-09-2009 4:48 PM
Turned off between 11pm and 8am...roughly.
Message 7 of 9
(743 Views)
02-09-2009 5:04 PM
Ok. It's dropping far too much for my liking.
Can you go to http://faults.plus.net and we'll get it raised to BT and hopefully they might just fix it this time.
Message 8 of 9
(743 Views)
02-09-2009 5:33 PM
James,
Tomorrow I want to test it with a couple of different filters and also with my laptop, so, when I've done that I will raise a fault if no different. Must say though, when BT came out before, the guy said there was no reason why I shoudn't be getting up to 6mbs....no problems with the line.
Thanks-Vincent
Thanks-Vincent
Message 9 of 9
(743 Views)
