Check my speed
- Check my speed
Check my speed
10-04-2013 9:22 PM
My broadband isn't up and running yet but where can I double check what speeds I can have?
Message 1 of 5
(1,787 Views)
4 REPLIES 4
Re: Check my speed
10-04-2013 9:33 PM
Message 2 of 5
(607 Views)
Re: Check my speed
10-04-2013 9:40 PM
SamKnows UK Broadband Availability Checker
Enter your phone number and postcode, and then on the following results page select each of the tabs going vertically down the middle of the screen to see what is available to you, and how fast it should be.
Message 3 of 5
(607 Views)
Re: Check my speed
11-04-2013 1:46 PM
An estimated speed should be visible to you after logging into the member centre on our website:
https://portal.plus.net/index_nlp.html
Message 4 of 5
(607 Views)
Re: Check my speed
11-04-2013 2:05 PM
Alternatively you could try the BT checker at http://www.dslchecker.bt.com/adsl/adslchecker.welcome - that will tell you what services are available and give you an idea of the speeds you could expect for each one.
Message 5 of 5
(607 Views)
