Check SNR?
- Re: Check SNR?
Check SNR?
22-02-2013 10:13 AM
How do I check the SNR on the techniclour router?
Matt
Matt
Message 1 of 4
(699 Views)
3 REPLIES 3
Re: Check SNR?
22-02-2013 10:20 AM
Message 2 of 4
(389 Views)
Re: Check SNR?
22-02-2013 10:31 AM
That just brings up the following...
Message 3 of 4
(389 Views)
Re: Check SNR?
22-02-2013 10:47 AM
You are on fibre to the cabinet (FTTC) and you will be unable to get your line stats via the Techniclor TG582N router. The only way to get the SNRM values is to hack the fibre modem, which is explained here: http://huaweihg612hacking.files.wordpress.com/2011/11/hg612_unlock_instructions_v1-3.pdf. Get the firmware from here: https://docs.google.com/folder/d/0B6wW18mYskvBZDE0YmNkMzAtZmEzMC00MjhiLTk2N2ItNDNhYTNjOGJlZTBj/edit?hl=en_US
Message 4 of 4
(389 Views)
