Check ADSL line speed on Plusnet Sagemcom router
sleepyjohn
Hi,  I'd like to make some regular measurements of the speed  my Plusnet Sagemcom router is running at on my ADSL line.
I've logged in to the router and hunted  through all the tabs there,  including "Advanced",  but failed to find anywhere it displays a speed.
Have I missed something or is it not possible on this router?
Note that I'm not talking about broadband speed such as  http://speedtest.btwholesale.com/ measures;  it's basic ADSL speed I'm after.
    +   John
1 REPLY 1
JayG
Fixes: 6
Re: Check ADSL line speed on Plusnet Sagemcom router
Data rate should be shown under 'Helpdesk'
More detailed stats are available if you log in as 'http://192.168.1.254/expert_user.html' (without the apostrophes.)
