Changing encryption key on +net supplied router
Len
I've just tried changing the WPA-PSK key this morning on my router.
I changed it on the router , my computer and my ipod.
All appeared OK and everything worked ok.
I went to lunch and then went out for an hour, came back and booted the computer , no wireless connection!
The router had reverted to its original key.
On checking I found that while I was out the router had rebooted , does this mean I have to change my key to what I want every time thing thing reboots?
I want to change it to something I can remember not an arbitary string of letters & numbers that has no mnemonic value at all.
len
