Changing broadband product
- Changing broadband product
16-12-2008 8:02 PM
I am on BbYW opt 2, and for the 3rd month in a row i am near to exceeding my usage with several weeks left until the end of this billing month!
I would like to upgrade to BbYW Opt 3.
If I do this, when will the new usage allowence come into effect? Immediately or in the next billing month?
Many thanks
Many thanks
Message 1 of 5
(1,015 Views)
4 REPLIES 4
Re: Changing broadband product
16-12-2008 8:03 PM
Generally it will be at the start of your next billing period, I think you can request it to be done sooner but you will be charged the pro-rated extra.
Message 2 of 5
(474 Views)
17-12-2008 8:15 AM
I have ticked the "pay as you go" box in the "upgrade my usage" section. I have not applied to upgrade my product yet.
Can someone from Plusnet please confirm that if I go over 15Gb now, I will be billed an extra 98p per gigabyte?
Message 3 of 5
(474 Views)
17-12-2008 8:44 AM
Yep, that's correct. On Option 2 you'll be billed 98p per GB if you are on flex. Have a look on this page for the information about this.
If you wanted to upgrade to Option 3, then it would happen nearly straight away, you'd need to pay the pro-rata difference between the 2 products to make the change.
Message 4 of 5
(474 Views)
17-12-2008 9:30 AM
@adiewoo
IIRC upgrades happen straight away but downgrades are postponed until your next billing date.
Quote Generally it will be at the start of your next billing period
Message 5 of 5
(474 Views)
