Changing NAT TYPE
- Changing NAT TYPE
Changing NAT TYPE
08-11-2011 10:03 PM
I play online on my ps3 and I want to set my NAT TYPE to open as it is currently on Strict.
Any help would be much appreciated. I am not the most technical of people so please be gentle.
Cheers,
Bish.
Re: Changing NAT TYPE
08-11-2011 11:52 PM
09-11-2011 1:48 AM
I've been trying for literally months with ports, DMZ'ing, etc etc and although it now shows as a type 2 connection, I actually think it cannot be done with a Thomson to get a truly "open" nat (type 1). So far as to say, I'm probably going to buy myself another modem, it's got that frustrating.
09-11-2011 3:04 AM
dick:quote
09-11-2011 2:23 PM
09-11-2011 3:02 PM
Please could you try the following on your routers to see if this improves the situation? You'll need to log into the router via telnet to enter these commands. The first 4 unbind commands may fail but the remaining 5 commands should run fine.
This will convert all unused ports above 54 to the CONE NAT type rather than symmetric - for UDP connections anyway.
Quote :connection unbind application=CONE(UDP) port=69
:connection unbind application=CONE(UDP) port=3074
:connection unbind application=CONE(UDP) port=3478-3479
:connection unbind application=CONE(UDP) port=88
:connection bind application=CONE(UDP) port=55-66
:connection bind application=CONE(UDP) port=68-499
:connection bind application=CONE(UDP) port=501-5059
:connection bind application=CONE(UDP) port=5061-7647
:connection bind application=CONE(UDP) port=7649-65353
09-11-2011 3:54 PM
09-11-2011 4:05 PM
Quote from: bishbosh77 Thanks Matt...but I hate to come across as stupid but what is telnet?
Sorry about that.
The article here: http://community.plus.net/library/hardware/forcing-adsl-modulation-on-thomson-585v7/ has a good description of how to connect to the router via telnet. You need to go as far as seeing the strange text based picture - just after you log on.
Your username and password to log on will probably be admin/the serial number of your router.
After logging on you need to copy and paste the commands above into the window. That is it.
09-11-2011 4:13 PM
Quote from: bishbosh77 I hate to come across as stupid but what is telnet?
Not stupid at all.
Telnet is a method of communicating with some routers (among other devices), it's run from a command prompt by typing 'telnet'.
In some versions of windows you will need to manually install telnet using 'add/remove windows features' or similar wording depending on the windows version.
09-11-2011 4:58 PM
09-11-2011 5:37 PM
:connection bindlist
And then reply with the result so we can take a look.
For those interested, if you have another application / game mapped within the port ranges specified in the commands then they'll fail - you can always re-write them to exclude ports already mapped.
09-11-2011 6:00 PM
10-11-2011 4:21 PM
