Changing Interface Type on Technicolor TG582n
- Changing Interface Type on Technicolor TG582n
30-05-2012 5:21 PM
Hi, anyone know the telnet command for changing the Interface Type on the Technicolor TG582n.
There is no option in the router's web interface and I want to change the setting from b/g/n to just g/n.
Thanking you.
Thanking you.
Message 1 of 6
(5,079 Views)
5 REPLIES 5
Re: Changing Interface Type on Technicolor TG582n
30-05-2012 5:33 PM
Hi, you can't change it to g/n there's no real point in that. If you wanted it set to just b/g then you could use the command
:wireless radio interop=802.11b/g
and
:wireless radio interop=802.11b/g/n
to change it back
Hope that helps. Jojo
and
to change it back
Message 2 of 6
(1,137 Views)
30-05-2012 5:40 PM
ok thanks
Message 3 of 6
(1,137 Views)
04-01-2013 12:01 PM
Could you tell me where I would input that command please ?
Message 4 of 6
(1,137 Views)
04-01-2013 12:12 PM
you need to telnet into the router
This gives the basic instructions on how to do it http://community.plus.net/library/dns/how-to-change-the-default-dns-servers-in-a-thomson-speedtouch-...
Message 5 of 6
(1,137 Views)
04-01-2013 3:58 PM
Thank you !!
Message 6 of 6
(1,137 Views)
