Changing FTTC + phone to FTTC only ? Router
Lindab
Hello, just taken advantage of new upgrade from FTTC plus phone line to Broadband only. Just had a message to say “please refer to the guide inside the box for router set -up instructions. I already have a router. Do I need a different router now? Many thanks from this confused elderly lady!!
2 REPLIES 2
Fixes: 387
Re: Changing FTTC + phone to FTTC only ? Router
If you already have a Hub2 - or even Hub1 - router, @Lindab , the answer is no.  The message is, I suspect, an auto-generated one due to your product change.
Lindab
Thanks so much Jab1. Much appreciated. Yes, I have a hub2
