Changed filter, IP profile increased, speed yet to?
- Changed filter, IP profile increased, speed yet to...
Re: Changed filter, IP profile increased, speed yet to?
07-03-2009 2:54 PM
07-03-2009 11:15 PM
Statistics Downstream Upstream
Line Rate 7616 Kbps 448 Kbps
Attainable Line Rate 8160 Kbps 1144 Kbps
Noise Margin 6.6 dB 22.0 dB
Line Attenuation 26.0 dB 21.0 dB
Output Power 12.4 dBm 19.8 dBm
18-03-2009 2:18 PM
Line Rate 8096 Kbps 448 Kbps
Attainable Line Rate 8800 Kbps 1144 Kbps
Noise Margin 5.3 dB 22.0 dB
Output Power 12.3 dBm 19.8 dBm
18-03-2009 3:06 PM
Yeh that sort of thing is a ruddy nuisance. As you've been monitoring your SNRM what sort of time of day does it typically get to a 6dB level previously? Don't reboot. What I would do is powerdown the router (make sure you're not going to get any more power cuts!!) about an hour before this, and then powerup at the right time, hopefully that will sort you out. The DLM should know the difference between a power down and as disconnect/reboot (as long as you don't unplug the line from the router.
HTH
PS. If your target should go back up, I'm sure a request to James will sort you out.
18-03-2009 6:21 PM
Noise Margin 4.1 dB 22.0 dB
Alan
18-03-2009 9:44 PM
18-03-2009 11:18 PM
Line Rate 6816 Kbps 448 Kbps
Attainable Line Rate 7360 Kbps 1128 Kbps
Noise Margin 8.5 dB 22.0 dB
Output Power 12.5 dBm 19.8 dBm
Alan
19-03-2009 12:06 AM
19-03-2009 9:07 PM
Alan
20-03-2009 8:55 PM
Alan
20-03-2009 9:05 PM
20-03-2009 9:22 PM
Line Rate 7648 Kbps 448 Kbps
Attainable Line Rate 8288 Kbps 1120 Kbps
Noise Margin 6.3 dB 22.0 dB
Output Power 12.3 dBm 19.7 dBm
21-03-2009 9:14 PM
Alan
Noise Margin 6.1 dB 22.0 dB
22-03-2009 1:38 PM
that looks a lot better, especially as it's been quite noisy from a propogation point of view yesterday.
It may not be the line that can't support the sync. but whether the router can hang on. This led me to thinking, do you have much overhead line or is most underground. In also checked that I hadn't commented on the fact that you stats suggest your line takes a more direct route to you from the exchange.
24-03-2009 9:34 PM
Alan
Line Rate 7360 Kbps 448 Kbps
Attainable Line Rate 7904 Kbps 1124 Kbps
Line Attenuation 26.5 dB 21.0 dB
