Change gateways
pcoventry76
Change gateways
Just for my own information. i've gone from Juniper 4 to Telehouse North, Juniper 6 but my modem hasen't resynced in 22 hours, and when it did i checked and it was on 4/
Just wondered why..
Pete
Fixes: 46
Re: Change gateways
The modem sync is with the exchange not the gateway.  Your broadband session will have disconnected from PlusNet and reconnected on a different gateway, but that doesn't affect the connection to the exchange (sync).
David
David
James
Re: Change gateways
We dropped a pipe yesterday as part of the planned maintenance.  So you wouldn't have dropped synchronisation, but your connection would have been dropped whilst your router reconnected onto a different pipe.
pcoventry76
Re: Change gateways
Thankyou guys Wink
