Change from fibre to adsl
I have a customer who has had fibre but has to down grade to normal adsl. She has the new plusnet router that does both systems. When she reverts back what does she have to do. Remove the modem and plug the line into dsl but does the line have to go into the phone or stay were it is in modem as she has the fibre plate. The change happens tomorrow but no instructions on what to do will the router need to be reconfigured or not
1 REPLY
Re: Change from fibre to adsl
The fibre plate is just a different version of the standard SSFP, so the DSL cable from whichever router you choose to use plugs in to the top port (RJ11) on the fibre ONT, which means no microfilters required.
